Displays the link-flap detection status for ports.
| ports | Physical ports. |
| port_list | List of ports that you want to see link-flap detection information. |
| all | Shows link-flap detection information for all ports in the system. |
| disabled-ports | Displays ports disabled due to excessive link flapping. |
| configuration | Displays link-flap detection configuration information: link-flap detection enabled status, link-flap detection actions enabled, threshold value, interval value. |
| counters | Displays counters related to link flapping. |
| refresh | Continuous refresh of output (default). |
| no-refresh | Page by page display without continuous refresh. |
Output is refreshed by default.
The following example shows link-flap detection configuration for all ports:
show ports all link-flap-detection configuration
Maximum threshold for interval of 10 seconds : 200
Port      Link-Flap Actions  Threshold     Interval  Disable Time
          Detection                         (secs)         (secs)
1         E         D--             20            6           200
2         E         D--             20            6           200
3         D         D-T             20 indefinitely until-cleared
4         E         D-T             20            5           200
5         D         D-T             20            5           200
6         D         D-T             10            5           300
> indicates Port Display Name truncated past 8 characters
Link-Flap Detection: (E) Enabled, (D) Disabled
Actions: (D) Disable port, (L) Generate log, (T) Generate SNMP trap
      The following example shows link-flap detection counter information for all ports:
show ports all link-flap-detection counters
Port Link-Flap Detection Counters
Port      Port     Current      Total       Time  Threshold
          State Link Flaps Link Flaps    Elapsed   Exceeded
                                          (secs)
1         E              0          0          0          0
2         E              0          0          0          0
3         D              0          0          0          0
4         D F           21         21          4          1
Port State: E-Enabled, D-Disabled, F-Disabled by link-flap detection
0->Clear Counters  U->page up  D->page down ESC->exit
      The following example shows ports disabled due to excessive link flapping:
show ports all link-flap-detection disabled-ports
Ports disabled due to excessive link flapping
Disabled            Remaining
Port(s)          Disable Time
                       (secs)
1               until-cleared
4                         150
> indicates Port Display Name truncated past 15 characters
    This command was first available in ExtremeXOS 22.1.
